14 years agoAdding and resizing in one step
Hi, Is there a way to add two unsigned numbers and extract only the x most significant bits from it in one step? I want something like this: sum <= resize(number1 + number2,4) In...
14 years agoIf your tool understands and supports the following:
sum = (num1 + num2)/2**4; Then it is equivalent to discarding 4 bits from result unless it goes silly and creates a division module. alternatively if you can accept truncation errors then: sum <= num1(6 downto 4) + num2(6 downto 4); is almost equivalent but division is done on operands.
