9 years agoAdding a second timer and generate a sof file
I could successfully run the uClinux 2.6 with a sof file that I downloaded from a tutorial. Now I must add a timer to the design and generate a sof file. How can I do that? When I try I get a t...
9 years agoThank you for the reply. I've only limited experience using Qsys and Quartus and the design I added a timer to was taken from Mahdi's tutorial how to boot MMU with DE2-115. The error msg looks like I have something wrong with the dts. It also appears if I try with linux 4.x from altera-opensource in github. I will try again and hope that we can solve it.
