9 years agoAdding a second timer and generate a sof file
I could successfully run the uClinux 2.6 with a sof file that I downloaded from a tutorial. Now I must add a timer to the design and generate a sof file. How can I do that? When I try I get a t...
9 years agoI don't know about the .dts, but the time limited is probably because you are using an IP that you don't have a license for.
