12 years agoADC+FPGA+DAC setup for predistortion
Hi, I am looking to buy the ADC12J4000EVM and DAC38J84EVM from TI. Both have an FMC connector and JESD204B interface. I am looking for a setup for predistortion and I would like to if there are...
12 years agoHi Nial,
--- Quote Start --- Yo Crazy Dave --- Quote End --- "Crazy busy" ... :) --- Quote Start --- I gave the JESD204B interface a very sparse review about 6 months ago, at the time Altera didn't have any free IP that could handle it. Have you had a look at what's available, and is there much to getting it running? Thanks for any thoughts, --- Quote End --- No, the IP is not free. Altera has two offerings; IP by MTI and Altera's own IP. The TI examples are based on the MTI IP (since it was available first). I have not tested either IP yet. TI's boards ship with some example firmware that show the FPGA interface works, and the ADC can sample signals. I have done some basic tests with that (to confirm the hardware and software setup works). Before using the MTI or Altera IP, and having the subtleties of JESD204B hidden from me, I want to get some basic transceiver interface tests working first, and then look at the JESD204B traffic ... once I have some data flowing, the JESD204B standard and the ADC data sheet will be easier to read, and then I can see if its easy enough to create the IP from scratch, or see if I should use the MTI or Altera IP. I'll post my results to the forum. Cheers, Dave
