14 years ago
ADC Timing Constraints
I feel like I see this question over and over, but can't quite figure out the answer.
I've got an 125 MHz clock coming in, from which I generate a 62.5 MHz clock using a TFF, which I then use to clock an ADC (ADS831). I sketched out a quick schematic showing what I'm talking about; the attached .gif. The Tcko on the ADC831 is 3.9-12 ns.
I've got the following constraints in my SDC file:
create_generated_clock -name adc_clk -source   -divide_by 2
#  ADC Input
set_input_delay -clock adc_clk -max 12.0 ]
set_input_delay -clock adc_clk -min 3.9  ]
set_multicycle_path -setup -end -from    -to   2
set_multicycle_path -hold  -end -from    -to   1
These constraints seem to be almost right, except I'm getting the always popular "Warning: No paths exist .... Assuming zero source clock latency." problem.
I've got Rysc's User Guide and Source-Synchronous Timing guides up, as well as the Timequest Cookbook and the API, and I've got to say I'm still stumped. Can anyone see what I'm missing here?
    Clocks don't propagate through FFs. You'll need two generated clocks, something like so:
    create_generated_clock -name tff_clk -source [get_ports {CLK_125_IN}] -divide_by 2 [get_keepers {*inst3*}]
    create_generated_clock -name adc_clk -source [get_keepers {*inst3*}] [get_ports {ADC_CLK}]
