8 years agoADC Hard Block primitive
Hello, Does anyone know where the documentation/HDL instantitiation templates for the ADC Hard Block is located? I want to configure and access the ADC directly without using the modular adc I...
8 years agoRefer to figure 8 in the ADC Timing section of the "max® 10 analog to digital converter user guide (http://max® 10 analog to digital)".
What you've instantiated there is essentially what results having configured the IP from the catalogue into 'Configuration 4: ADC Control Core Only'. Refer to section 2.2.1 "Altera Modular ADC IP Core Configuration Variants", in the same document. Cheers, Alex Edit **Sorry - need to acknowledge that's exactly what you said you did...
