8 years agoADC Hard Block primitive
Hello, Does anyone know where the documentation/HDL instantitiation templates for the ADC Hard Block is located? I want to configure and access the ADC directly without using the modular adc I...
8 years agoInstantiating isn't really the problem... I dug through the output of the "megawizard" or whatever that thing is called. Here is how you instantiate it in VHDL:
component fiftyfivenm_adcblock
generic(
-- 3-bits 1st stage clock divider.
-- 0..5 = DIV by 1/2/10/20/40/80;
-- 6..7 = invalid
clkdiv : integer := 0;
-- 2nd stage clock divider.
-- 0 = DIV by 10;
-- 1 = DIV by 20
tsclkdiv : integer := 0;
-- 0 = Use 1st stage clock divider when TSEN.
-- 1 = Use 2nd stage clock divider when TSEN.
tsclksel : integer := 0;
-- 2-bits To enable the R ladder for the prescalar input channels.
-- 00 = disable prescalar for CH8 and CH16 (CH8 for device with 2nd ADC)
-- 01 = enable prescalar for CH8 only
-- 10 = enable prescalar for CH16 only (CH8 for device with 2nd ADC)
-- 11 = enable prescalar for CH8 and CH16 (CH8 for device with 2nd ADC)
-- please note that this is not supported in VR mode
prescalar : std_logic_vector(1 downto 0) := "00";
-- Reference voltage selection for ADC.
-- 0 = external;
-- 1 = internal VCCADC_2P5
refsel : integer := 0;
-- Ordering Part Number 10MXX... code
device_partname_fivechar_prefix : string := "10M04";
-- Some part have two ADC, instantiate which ADC? 1st or 2nd?
-- Valid options: 1 or 2
is_this_first_or_second_adc : integer := 1;
-- 16 bits to indicate whether each of the dual purpose analog input pin (ADCIN) is in use or not.
-- 1 bit to indicate whether dedicated analog input pin (ANAIN) is in use or not (bit 16)
analog_input_pin_mask : integer := 0;
-- Power Down. Use to disable the ADC during compilation time if no ADC is in use.
hard_pwd : integer := 0;
-- Logic simulation parameters which only affects simulation behavior
enable_usr_sim : integer := 0;
reference_voltage_sim : integer := 65536;
simfilename_ch0 : string := "simfilename_ch0";
simfilename_ch1 : string := "simfilename_ch1";
simfilename_ch2 : string := "simfilename_ch2";
simfilename_ch3 : string := "simfilename_ch3";
simfilename_ch4 : string := "simfilename_ch4";
simfilename_ch5 : string := "simfilename_ch5";
simfilename_ch6 : string := "simfilename_ch6";
simfilename_ch7 : string := "simfilename_ch7";
simfilename_ch8 : string := "simfilename_ch8";
simfilename_ch9 : string := "simfilename_ch9";
simfilename_ch10 : string := "simfilename_ch10";
simfilename_ch11 : string := "simfilename_ch11";
simfilename_ch12 : string := "simfilename_ch12";
simfilename_ch13 : string := "simfilename_ch13";
simfilename_ch14 : string := "simfilename_ch14";
simfilename_ch15 : string := "simfilename_ch15";
simfilename_ch16 : string := "simfilename_ch16"
port(
chsel : in std_logic_vector(4 downto 0); -- 5-bits channel selection.
soc : in std_logic; -- signal Start-of-Conversion to ADC
eoc : out std_logic; -- signal end of conversion. Data can be latched on the positive edge of clk_dft after this signal becomes high. EOC becomes low at every positive edge of the clk_dft signal.
dout : out std_logic_vector(11 downto 0); -- 12-bits DOUT valid after EOC rise, still valid at falling edge, but not before the next EOC rising edge
usr_pwd : in std_logic; -- User Power Down during run time. 0 = Power Up; 1 = Power Down.
tsen : in std_logic; -- 0 = Normal Mode; 1 = Temperature Sensing Mode.
clk_dft : out std_logic; -- Output clock from the clock divider
clkin_from_pll_c0 : in std_logic -- Clock source from PLL1 c-counter at BL corner or PLL3 c-counter at TL corner
end component;
I just want to find the documentation that explains the timing between EOC, SOC, DOUT, etc. I don't like to make comparisons but Xilinx has all their hard ip blocks well documented. Surely something similar must exist for Altera/Intel parts? I am rather concerned that "fiftyfivenm_adcblock" has 4 google results. The modular ADC is not an option for us seeing our design is going to be so tightly constrained by space limitations. The Modular ADC IP (even in it's smallest incarnation) is quite a bit larger than is needed.
