12 years agoActive serial programming not working Cyclone II starter development board
I am using Quartus II free web edition, 12.1 Build 177, not whatever was on CD that came in the starter kit, EP2C20F484C7N, (I used this version okay with CPLD EPM1270. The board has a EPCS4...
12 years agoI respectfully disagree : see cut past from screen- I don't understand how the tools is suppossed to understand I am ultimately programming a cyclone II chip, but I am writing the program to EPCS4. Can you point to directions for file conversion you mentioned.
thanks --------------------------- Flow Status Successful - Tue Sep 17 10:51:52 2013Quartus II 32-bit Version 12.1 Build 177 11/07/2012 SJ Web Edition Revision Name code1 Top-level Entity Name code1 Family Cyclone II Device EP2C20F484C7 Timing Models Final Total logic elements 245 / 18,752 ( 1 % ) Total combinational functions 170 / 18,752 ( < 1 % ) Dedicated logic registers 147 / 18,752 ( < 1 % ) Total registers 147 Total pins 16 / 315 ( 5 % ) Total virtual pins 0 Total memory bits 0 / 239,616 ( 0 % ) Embedded Multiplier 9-bit elements 0 / 52 ( 0 % ) Total PLLs 0 / 4 ( 0 % )
