11 years agoActive Serial Programming ISSUE EPCS16 EP4CE15
Dear friends, i have designed and assembled my first fpga board and have some issues with the active serial programming. After programming the config device via usb blaster (which states 100% succ...
11 years ago --- Quote Start --- You are on to your problem. (Athough I get a different MSEL config for 3.3) MSEL 0 = H MSEL 1 = L MSEL 2 = L (for standard AS mode 3.3V) MSEL 0 = H MSEL 1 = L MSEL 2 = H (for fast AS mode 3.3 V) --- Quote End --- Hello Pete, i will try to cut/desoder the pin and connect it via a wire to the next vcc via, but i am curious if your or my suggested levels are correct (i do not want to change an error or another). In the cyclone iv device handbook, page 173, table 8.5 is stated http://www.alteraforum.com/forum/attachment.php?attachmentid=10833&stc=1 Could you please confirm this, or am i making a mistake? Thank you very much for your help, i appreciate it. Best regards Nenad
