ZKhan1
3 years agoActive Serial Multi Device Configuration issue
Hi ,
I have a board with x02 Cyclone 10 Lp , part number : 10CL040YF484C8G , they are connected in Active Serial Multi Device config with first FPGA the master configurer .
But the schematic d...
AqidAyman_Altera
3 years agoHi,
As far as I understand, you need to connect as per user guide if you are having multiple FPGA in Active Serial mode. If the configuration pin is connected wrongly, it will cause configuration error.
regards,
Aqid
