16 years agoActive serial (AS) configuration problem
I have a number of boards that are failing configuration - about a quarter of the boards in fact. Setup: EP3C16F484 configured with a EPCS16 MSEL[] = 0010 - AS standard POR at 3.3V Circuit ...
16 years agoThere's a big chance the EPCS is broken. I've seen that several times lately. Exactly the behaviour you describe. I don't know why these devices are so expensive. They fail regularly.
Good luck, Ton
