13 years agoAccessing HPS Pins
Hello, I know I can route HPS pins to the FPGA side but is it possible to do the opposite, route FPGA side logic to HPS part pins? Thank you
12 years agoThe HPS loan I/O issue went from bad to worse for me, as we couldn't even successfully drive out a 1Hz signal. The cause was my exceptional ignorance...
It turns out that the HPS I/O are entirely controlled by software (via an HPS h/w block called the System Monitor). So in order for the pinmuxing configuration to take effect, one must build a custom preloader, as described in http://www.rocketboards.org/foswiki/documentation/preloaderubootcustomization We don't have this working quite yet, since we are running into issues building the preloader, but I'll post any updates here.
