16 years agoAccessing DDR2 SDRAM without using Nios processor.
Hi all. I am making a video elaboration system, and i would like to perform a real time elaboration. I need to perform many video elaborations on many entire video frames, so i need to be able ...
16 years agoThanks for your reply.
Well, I tink i've already seen it, and i am still trying to work out with the frame reader. I'll take another but i need to take the video pakets over the avalon-st interface and save them for an entire field as image into the SDRAM. then, read that image with a custom block, not with the frame reader, then save the processed image into a new memory (maybe SSRAM this time) and then read the processed image with the frame reader. My problem is how can i access the SDRAM to write and then how can i read from that writing a custom block? wich are the signals I need to interface with the SDRAM DDR2 hp controller provided by Altera? Anyway, if there are more simple way to make something like that, i would choose the simple way! Thanks a lot for the reply best regards Phate.
