Accessing code on a Max10 FPGA
Connection how? Thru the JTAG interface, or some other means?
By 'push code to it' do you mean program your device thru JTAG?
Do you implement some type of custom JTAG interface module in your code?
Those functions (read data, write data, etc) are not standard embedded JTAG functions.
You would have to define JTAG USER0 and/or USER1 functions that are recognized and implement the appropriate features in your logic.
We're connected by means of a usb blaster cable.
By push code I mean program the FPGA using bash script to execute files compiled from Quartus Prime.
Our test procedures for communicating with the Altera Max10 FPGA were written back before they were bought by intel and the connection was accomplished via the fs2nios cable. Back then there was documentation (I assume) for the fs2nios.dll which was part the cable driver installation software which enabled us to use those functions.
After Intel bought Altera they shifted over to the USB Blaster cable and its software contains dll's that serve the same purpose but I haven't been able to find any documentation on how to use its functions. If it was a simple as swapping out one dll for another I'd be golden but it seems I've got to do things the hard way.
With Xilinx FPGA's you can alter configurations of the FPGA to get it to perform its necessary functions on the physical level, then write/read to certain I/O elements to perform debugging and diagnostic functions in conjuction with the tasks being performed by the FPGA's physical layer. I'm looking to do something similar with the Altera Max10 FPGA.
I found documentation about the external memif toolkit that has a bunch of the functions I'm looking for such as
establish_connection (::quartus::external_memif_toolkit)
terminate_connection (::quartus::external_memif_toolkit)
read_setting (::quartus::external_memif_toolkit)
apply_setting (::quartus::external_memif_toolkit)
run_connection_command (::quartus::external_memif_toolkit)
get_connection_commands (::quartus::external_memif_toolkit) get_connection_info (::quartus::external_memif_toolkit)
I have experience using Xilinx and NI FPGA's but unfortunately flavor of them is all very new to me so please forgive me if I confuse you with incorrect terminology. Let me know if I'm on the right track as far as communicating with the FPGA for testing/debugging purposes or if there's a much easier way to accomplish what I'm setting out to do.
Thanks!
