UMEPU's avatar
UMEPU
3 years ago
Access Violation with 22.3 programmer
Dear Sirs.
I am trying to write a very simple SOF to my Stratix10GX (1SG085HN3F43E1VG) board with Quartus 22.3 and Windows10 64bit.
I get the message as followings: (GUI show 23%)
Info: Command: quartus_pgm -c 1 -m jtag -o p;sample_top.sof@2 --debug
Info (213045): Using programming cable "USB-BlasterII [USB-1]"
Info (213011): Using programming file sample_top.sof with checksum 0x1DD1ADD3 for device 1SG085HN3F43@2
Info (209060): Started Programmer operation at Mon Nov 21 16:02:09 2022
Info (18942): Configuring device index 2
*** Fatal Error: Access Violation at 00007FFE8FECA5BA
Module: quartus_pgm.exe
Stack Trace:
Quartus 0x11a5b9: PGMALGO_API_PGM::send_s10_program_data + 0xba9 (pgm_pgmalgo)
Quartus 0x160cf8: PGMALGO_DO_SDM_CONFIGURE::execute + 0x1948 (pgm_pgmalgo)
Quartus 0x656c9: PGME_UNIFIED_ALGORITHM::do_algo + 0x3b39 (pgm_pgme)
Quartus 0xc8a43: PGME_UNIFIED_ALGORITHM::program + 0x553 (pgm_pgme)
Quartus 0x6dea8: PGME_PROGRAMMER::engage + 0x1388 (pgm_pgme)
Quartus 0x377d6: QPGM_FRAMEWORK::execute + 0x1126 (quartus_pgm)
Quartus 0x1fdcc: qexe_do_normal + 0x4cc (comp_qexe)
Quartus 0x29753: qexe_run + 0x683 (comp_qexe)
Quartus 0x2aa0a: qexe_standard_main + 0x26a (comp_qexe)
Quartus 0x4ca0b: qpgm_main + 0x6b (quartus_pgm)
Quartus 0x27b68: msg_main_thread + 0x18 (CCL_MSG)
Quartus 0x28b22: msg_thread_wrapper + 0x82 (CCL_MSG)
Quartus 0x2aae3: mem_thread_wrapper + 0x73 (ccl_mem)
Quartus 0x25088: msg_exe_main + 0x178 (CCL_MSG)
Quartus 0x4fc2b: __scrt_common_main_seh + 0x10b (quartus_pgm)
Quartus 0x174b3: BaseThreadInitThunk + 0x13 (KERNEL32)
Quartus 0x526a0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Do you have any idea about this error message?
MSEL is AS fast-mode, and I cannot change MSEL (too narrow space to change).
I can write SDM default SOF to write JIC file and verify is also good.
I try to write SOF with 22.2 and 20.3, but it is also failed. (error message is different)
If you have any idea which I should try or anything, please let me know.
Thank you for your cooperation.
With Best Regards.
  • Dear Fakhrul
    Yes Quartus programmer. But now it seems to be OK. After reboot my PC, Quartus Programmer is working well.
    With Best Regards.
    -- toshi//
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hi UMEPU,
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Fakhrul
  • UMEPU's avatar
    UMEPU
    Dear Fakhrul
    With Best Regards.
    -- toshi//
