17 years agoAbout the cycloneIII IO output speed
hi everybody I'm trying to use the EP3C25F324C8 to generate 250MHz clock as high speed AD(AD9481) clock,could it work?I don't know if the user IO (3V3 LVTTL)or PL...
17 years agoAssuming that you successfully manage to generate a 250MHZ clock in your FPGA then 250MHz is probably too fast for LVTTL outputs.
Consider using differential LVDS or similar standards for output pins
