16 years agoabout niosII
Hi, I write in NiosII this instruction int a,b; int r; a=4; b=98; r=a&&b; the problem i have a message error ,when i use && ,I don't know why ? can sameone help me to use this com...
16 years ago --- Quote Start --- for(int i=1;i<height-1;i++){ for(int j=1;j<width-1;j++) --- Quote End --- You can't define variables inside the for loop instruction. This mode is not supported by Nios C compiler. Declare i and j with other variables. --- Quote Start --- int **IM ,**im1; --- Quote End --- IMHO this declaration is ambiguous if you then use these pointers to address a bidimensional array. You don't specify dimensions, so, how can compiler know how to map array indexes to memory? --- Quote Start --- IM[i][j]=r --- Quote End --- Semicolon missing Regards Cris
