Yamada1's avatar
Yamada1
2 years ago
About Max10 power connection
I was planning to use 10M02SCE144I7G and proceeded with reference to the Pin Connection Guidelines.
was also using the circuit diagram of "EK-10M08E144" as a reference, but I noticed some differences with the guidelines.
It would be helpful if you could teach me the following points.
1) According to the guidelines, the regulators for VCC_ONE and VCCIO are separate in any single supply configuration example. On the other hand, in the circuit diagram of "EK-10M08E144", although a 0.1Ω resistor is included, VCC_ONE and VCCIO are supplied from the same regulator. Is there any problem with the connection?
2) In the guidelines, "Share" is written in the Regulator Sharing column of VCC_ONE and VCCIO. There is no specific explanation, but is it okay to assume that VCC_ONE and VCCIO can be supplied from the same regulator as long as the voltage used is the same?
We apologize for the inconvenience and appreciate your understanding.
  • lixy's avatar
    lixy
    According to the Max 10 Power Management User Guide, Chapter 2.1.3,
    "For Intel® MAX® 10 single-supply devices, only one power supply is required—3.0 V or 3.3 V to power the core of the FPGA. The same power supply can be used to power the I/O if the same 3.0 V or 3.3 V voltage is required. "
    https://www.intel.com/content/www/us/en/docs/programmable/683400/18-0/comparison-of-the-power-supply-device.html
    So it is correct that "VCC_ONE and VCCIO can be supplied from the same regulator as long as the voltage used is the same".
    XY
    • Yamada1's avatar
      Yamada1
      Thank you for answering.
      Thank you very much for your help.
