About Max10 power connection
- 2 years ago
According to the Max 10 Power Management User Guide, Chapter 2.1.3,
"For Intel® MAX® 10 single-supply devices, only one power supply is required—3.0 V or 3.3 V to power the core of the FPGA. The same power supply can be used to power the I/O if the same 3.0 V or 3.3 V voltage is required. "
So it is correct that "VCC_ONE and VCCIO can be supplied from the same regulator as long as the voltage used is the same".
XY
XY
- Yamada12 years ago
Thank you for answering.
Thank you very much for your help.
