About Max10 power connection
- 2 years ago
According to the Max 10 Power Management User Guide, Chapter 2.1.3,
"For Intel® MAX® 10 single-supply devices, only one power supply is required—3.0 V or 3.3 V to power the core of the FPGA. The same power supply can be used to power the I/O if the same 3.0 V or 3.3 V voltage is required. "
So it is correct that "VCC_ONE and VCCIO can be supplied from the same regulator as long as the voltage used is the same".
XY
XY
Thank you for answering.
Thank you very much for your help.
