9 years agoabout MAX V open drain output maximum voltage
Hi, Where can I find info about MAX V open drain output max. voltage value? Can I drive directy LED ( 3,2V drop voltage at 10 mA) from MAX V open drain output if the LED Anode connected to...
9 years agoNo. You can't connect an LED directly to the pin in this way. Refer to the 'max v datasheet (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-v/mv51003.pdf)'. Absolute max on a pin is 4.6V let alone the recommended operating conditions of 3.6V max.
Use an external transistor or FET if you want to operate at 5V. Cheers, Alex
