wzhen25
7 years agoAbout LVDS SERDES Intel FPGA IP(Stratix 10)
In recent, I 'm working a project that requires LVDS receiver, and the LVDS receiver needs be configured to external PLL mode and DPA mode. When I set the parameter "reference clock" of the external...
SreekumarR_G_Intel
7 years agoJust to make sure what I understood from your statement is , with 100 MHz reference clock on PLL everything working fine , but when you change the reference clock to 333.33 MHz ; dpa_locked is not asserting after pll_locked assert ,correct ?
Are you using eval board or custom board ? if you have a eval board can you check once ?
Thank you ,
Sree
