about cyclone 10gx transceiver
Also, just to make sure I am clear, expected settings
ON RX SiDE
RX FIFO mode = Phase compensation
Enable block sync = ON
Enable rx_enh_blk_lock = ON
Enable rx_bitslip = optional (not needed anymore)
Thank you for you reply. But unfortunately, when I enable Rx block synchronizer, error appear, as shown in the following figure.
- Ash_R_Altera2 months ago
The Rx block synchronizer works when 'Enhanced PCS/PMA interface width' = 40 or 64, 'FPGA fabric / Enhanced PCS interface width' = 66 and 'Enable RX data bitslip' = Unchecked.
Please try these settings.
- SiWu2 months ago
Thanks a lot for your reply. From your description, can I say that when 'Enhanced PCS/PMA interface width' = 32, there is no way to send and receive data correctly?
For your original settings with 'Enhanced PCS/PMA interface width' = 32. Try changing the Enhanced PCS RX FIFO mode to Register instead of phase compensation mode.
