Yamada1
3 years agoAbout Arria10 Embedded Memory rden signal
It would be helpful if you could tell us the following points about the rden signal input to the RAM block.
1) Reading is valid when rden is 'H', but is the read address latched even if rden is 'L'...
- 3 years ago
Yes, the data output retains the previous values that are held during the most recent active read enable. Which is dout0.
You can see the same thing in figure 4 as well.
No worry. I am happy to help.
Richard Tan
p/s: Please do expert delay in response due to lunar new year.
Yamada1
3 years agoThank you for your answer.
Thanks to you, I was able to solve the problem.
Thank you for your kind response.
