A10 Vertical migration with regard of NC pins
- 3 years ago
Hi PK,
You do not need to worry to connect the NC pin to the GND or VCC as long as they in the same migration path. You need to identify the package for both device and check if they are in the same migration path. Refer the link below:
I/O Vertical Migration for Intel® Arria® 10 Devices
This Knowledge Base (KDB) article also have explained on this as link below:
When migrating between two devices in the same package, NC pins on... (intel.com)
I hope it clarifies.
Aqid
Hi PK,
Aqid
- PeroK3 years ago
Thanks this is what I wanted to know!
Best,
PK
