A10 AVMM DMA has only a single MSI to Host, how to distinguish this DMA completion is from READ DMA controller, or from WRITE DMA controller?
Hi SK,
I'm checking A10 AVMM DMA reference linux driver code (gen3x8_avmm_dma_Linux), in " altera_dma.c " file -> dma_test() function, there are below code :
last_id = last_id + bk_ptr->dma_status.altera_dma_descriptor_num; /// calculate to get new "last-id" param
if(last_id > 127){
last_id = last_id - 128;
if((bk_ptr->dma_status.altera_dma_descriptor_num > 1) && (last_id != 127)) write_127 = 1; /// check whether "last-id" roll back to "descriptor[] head"
if(write_127) iowrite32 (127, bk_ptr->bar[0]+DESC_CTRLLER_BASE+ALTERA_LITE_DMA_RD_LAST_PTR); /// (--- 1 )
iowrite32 (last_id, bk_ptr->bar[0]+DESC_CTRLLER_BASE+ALTERA_LITE_DMA_RD_LAST_PTR); /// (--- 2 )
Here to my understand it write "id" into LAST_PTR to start DMA operation. But why can the "LAST_PTR" be be written twice continueously ?
To my understanding, the second iowrite32 (last_id, .. ) will overwrite the first iowrite32 (127, ..).
Does DMA Controller support the sequence writing : iowrite32 (a,) -> iowrite32 (b,) -> iowrite32 (c,) -> iowrite32 (d,) .. And still keep running correctly ?
Can you clarify a bit. Thanks
In https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_avmm_dma.pdf, there are sentence in page 81 as following :
" .. host software should write multiple IDs into the last pointer register. as example :
- Program the RD_DMA_LAST_PTR = 63.
- Program the RD_DMA_LAST_PTR = 127.
- Poll the status DWORD for read descriptor 63.
- Poll the status DWORD for read descriptor 127
Does this explain it from Intel perspective ?
