18 years agoA very basic newbie question
Hi All
I have a very basic question. I've recently started learning about CPLD and VHDL. My VHDL code usually compiles and simulates fine, but when I put it in an actual CPLD it behaves really strange. I'm sure you have all been there. Could you please solve this mystery for me? Basically what I am doing is dividing the global clock by 500, and incerementing a counter to show the value on a seven segment. This is the very simple code, I am using MAX EPM7128SLC84-15:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
-- this is the entity
Entity V2 Is
Port (
GClk : In std_logic; --Global clock, pin 83
SS : Out std_logic_vector(6 Downto 0); -- Connected to the Seven Segement
End V2;
Architecture RTL of V2 is
Signal MyClk : std_logic; -- The divided clock
Signal SevSegVal : std_logic_vector(6 downto 0);
Begin
Process (GClk)
Variable Count : Integer Range 0 To 1023 := 0;
Begin
If (rising_edge(GClk)) Then
Count := Count + 1;
If (Count = 500) Then
Count := 0;
MyClk <= Not MyClk;
End If;
End IF;
End Process;
PROCESS (MyClk)
Variable Counter : Integer Range 0 To 9 := 0;
Type SSValues Is array(integer range 0 to 9) Of std_logic_vector(6 downto 0);
Variable Values : SSValues := (('1', '0', '0', '0', '0', '0', '0')
, ('1', '1', '1', '1', '0', '0', '1')
, ('0', '1', '0', '0', '1', '0', '0')
, ('0', '1', '1', '0', '0', '0', '0')
, ('0', '0', '1', '1', '0', '0', '1')
, ('0', '0', '1', '0', '0', '1', '0')
, ('0', '0', '0', '0', '0', '1', '0')
, ('1', '1', '1', '1', '0', '0', '0')
, ('0', '0', '0', '0', '0', '0', '0')
, ('0', '0', '1', '0', '0', '0', '0')); -- To hold the bit pattern for the seven segment numbers
Begin
If (rising_edge(MyClk)) Then
SevSegVal <= Values (Counter);
If (Counter = 9) Then
Counter := 0;
Else
Counter := Counter + 1;
End IF;
End If;
End Process;
SS <= SevSegVal;
End RTL;
This code simulates fine in Quartus II using a vector waveform file. But doesn't work properly when I upload it to my development board. The problem is the the seven segment flickers. I can see it count, but the lamps that are supposed to be off for each number flicker dimly. From what I can see, Quartus II (v 8.0) synthesizes this code to a latch which is clocked by MyClk, which goes to high impedance during the wait and causes the lines to float and flicker. Am I right? To me, it seems I am violating some 'well-known' rules for writing synthesizable code that actually works in real hardware. What am I doing wrong? What is the correct way of dividing a clock and incrementing a seven segment counter? I really really appreciate your help.13 Replies
First of all you may try to down-speed your implementation, as FvM suggests. Go to very low frequencies and check out the result.
Then take care about the current driving the 7-segments modules, be sure that the current (either directly generated by the CPLD or through a buffer) is within the specified acceptable range. - Altera_Forum
--- Quote Start --- The Count and Counter in the RTL represent actual objects (FFs) in real design, so you must declare them as signal and use <= instead of :=. --- Quote End --- I don't agree. The variables are effectively treated by Quartus as signals here. A different behaviour is only in cases, when the variable is used in other expressions after assigning a new value. The Quartus VHDL templates are showing the same counter style, BTW. The design uses a ripple clock, which would cause timing issues if the primary GCLK shall be used in connection with the derived MyClk. Cause both clock domains are strictly separated, it's O.K. The RTL view looks O.K., the Technology Map is somewhat special with MAX7000, but seems to represent a meaningful synchronous design, as expectable from the code. May it be the case, that your input clock is simply too fast to view anything? - Altera_Forum
The Count and Counter in the RTL represent actual objects (FFs) in real design, so you must declare them as signal and use <= instead of :=. Thanks
