18 years agoA very basic newbie question
Hi All I have a very basic question. I've recently started learning about CPLD and VHDL. My VHDL code usually compiles and simulates fine, but when I put it in an actual CPLD it behaves really...
18 years ago --- Quote Start --- The design uses a ripple clock, which would cause timing issues if the primary GCLK shall be used in connection with the derived MyClk. Cause both clock domains are strictly separated, it's O.K. --- Quote End --- --- Quote Start --- Although in principle there is nothing necessarily wrong with using two clocks as you have done, clocks/global signals are generally not in abundance in FPGAs/PLDs. Personally I would generate a clock enable pulse rather than another clock and then use a clock enabled register to drive the display. --- Quote End --- Even though it's apparently not critical for this design, in general you should follow batfink's advice. See http://www.alteraforum.com/forum/showthread.php?t=2388 for more information about driving clocks with registers or combinational logic versus using the preferred clock enable.
