17 years agoa strange problem!
module zhengxing(clk_200M, rst, data_in, data_out ); input clk_200M; input rst; input data_in; output data_out; reg data_out; reg [2:0]counter; reg [1:0]state; parameter low...
17 years ago --- Quote Start --- 200 MHz, generated from your PLL, is a rather fast clock for a Cyclone-II. 1) Make sure with the TimeQuest Timing Analyzer that your design meets the timing requirements. (200 MHz means a 5nsec clock period). 2) You could first try to feed your design with a slower clock and debug it. You could take your external clock signal for that. That is probably much lower than the 200 MHz. --- Quote End --- i also try it with 20M,it doesn't work ! this is the a picture of timing analyzer!
