15 years agoA strange JTAG configuration problem
I worked with FPGA for years but this time there's a really interesting problem comes to me: My board can be configured successfully through JTAG only at the very first time after my PC restart...
15 years ago --- Quote Start --- So if I understand right, after you configure the board you can run jtagconfig but you can't do another sof download? That's quite odd. What does `netstat -ano | grep 1309` give you? I think this command puts the process number on the right hand side of the result. Are there any processes with established connections to jtagserver? If so then what are they? --- Quote End --- Yes, this is an odd problem. I can use JTAG to configure the board only once, and if I want to use JTAG to configure the board again, I have to restart my computer. Even log-off does not work. I changed to use another computer with windows7 32-bit, same phenomena. I'm quite not familar with the windows processes stuff. Now I'm going to use PROM to configure the FPGA, if PROM works then I'll forget the JTAG.
