15 years agoA question about fitting resource usage summary
I have synthesis an Opencore to FPGA DE0 board, and I see the fitting resource usage summary in the compilation report which shows as below Total logic elements 2,039 / 15,408 ( 13 % ) Combinat...
8 years ago --- Quote Start --- Thanks Tricky; The email address of the authors donot work.....Jshmalet is the author and hence I am trying to approach him. Also the top level module is missing --- Quote End --- Generally I never trust anything from OpenCores. I have found stuff to lack documentation, have poor coding styles and as you have found, missing modules. If you need support you are reliant on the original author, who may not have worked on it for a long time, or not be interested. Generally, use at your own peril.
