11 years agoa problem when use altremote_update mega function in cycloneIV E
I am planing to use altremote_update mega function to update remotely .Currently I am doing some tests on this mega function . What I am trying to do is to have 2 SOFs .1 for factory image and th...
11 years agoHello all,
Problems above has been solved ,root cause is my partner put the wrong resistor between VCC and pin nSTATUS .The actual resistor is not 10K ohm but 10 ohm .So nstatus is always high ,and FPGA is just waiting for the negedge of nSTATUS . Just share it with all of you ,hope that would help more or less . BTW , I found this forum really helpful to me ,I've leant a lot here.
