12 years agoA problem when building preloder image file
Hello, I want to build preloder image file. I open BSP editor and build a new BSP.It generate a .bsp file.Then I press the generate button,and it start to generate. But it stayed in this interface...
12 years agoI met your problems and solved this problem.
You should update the Qsys components for 14.0 and recompile the project in quartus ii 14.0. then you can use bsp-editor to build the preloder image file.
