12 years agoA problem when building preloder image file
Hello, I want to build preloder image file. I open BSP editor and build a new BSP.It generate a .bsp file.Then I press the generate button,and it start to generate. But it stayed in this interface...
12 years agoUsing the example project in E:/Altera/14.0/embedded/examples/hardware/cv_soc_devkit_ghrd, I successfully build the preloader image file and device tree.But I still don't understand why I can't use GHRD in DE1-SOC_V.1.2.0_SystemCD.
Anyway thank you for sloving my problem. I will try out if I can build preloader image file successfully after I edit this example.
