12 years agoA problem when building preloder image file
Hello, I want to build preloder image file. I open BSP editor and build a new BSP.It generate a .bsp file.Then I press the generate button,and it start to generate. But it stayed in this interface...
12 years agoIf your project is equal with Altera-s, I create d:/alteraproject/de1_soc_GHRD (sorry, E: absent), copy there all from C:/Altera/14.0/embedded/examples/hardware/cv_soc_devkit_ghrd (200M), delete all subfolder software/spl_bsp (created if before experiment), run Shell in 6 retryes, bsp-editor from these, choose File/New BSP, select path for create project to d:/alteraproject/de1_soc_GHRD/hps_isw_handoff/soc_system_hps_0, create BSP, press Generate -- 1 sec, and OK! Then press Exit, in Shell press "cd d:/alteraproject/de1_soc_GHRD/software/spl_bsp", "make", and in 2 minutes Preloader its ready.
My system is analogous. Try similarly make Preloader in original folder, then copy it to work folder, recompile, and only then edit GHRD.
