12 years agoA problem when building preloder image file
Hello, I want to build preloder image file. I open BSP editor and build a new BSP.It generate a .bsp file.Then I press the generate button,and it start to generate. But it stayed in this interface...
12 years agoMy OS is windows 7 ,64 bit. My archived folders is in E:\alteraproject\de1_soc_GHRD. I used Altera-s original GHRD, and it came out as the picture shows before.
My Altera Embedded Command Shell is 14.0. I will try 13.1 later.
