12 years agoA problem when building preloder image file
Hello, I want to build preloder image file. I open BSP editor and build a new BSP.It generate a .bsp file.Then I press the generate button,and it start to generate. But it stayed in this interface...
12 years agoIn detail describe all your operations and include your archived folders, please. If not secret.
We also try, and if retryes, will be send this example to Altera. If try using Altera-s original GHRD, no problem ? I generate it fastest than 1 sec. Before this bad state, was moments, when Generate work ? This is now very stable behaviour ? If I run Altera Embedded Command Shell 14.0, permanently see strange messages as "bash: cannot set terminal process group: no job control in this shell", "Innappropriate ioctl for device", in 2/3 cases Shell generally appears and fast closes, error message is not visible. In 13.1 all was OK. Try you differing versions of SoC ? 4 now available on Altera site.
