LJens1
6 years agoA new Altera USB Blaster, Rev C stopped working. Error code given in programming software says: BAD 209012 Operation Failed.
Altera USB Blaster, Rev C for programming. I have moved this USB blaster to another computer, same issue. Another blaster was put on this computer, same setup, worked. Is there any way to get this ...
ShafiqY_Intel
6 years agoHi LJen1,
The error message 209012 can be caused by one of the following situations:
- Communications cables not securely connected
- Incorrect device selected
- No power to target system
Have you try command "jtagconfig' your new USB Blaste device? and, please show me the screenshot of jtagconfig.
- open Command Prompt ---> go to Quartus directory <Quartus installation directory>intelFPGA\18.1\quartus\bin64> ---> run jtagconfig
Cheers
