a few questions about using Virtual JTAG ip core
Dear experts,
I've met a problem when I was researching that how to use a virtual JTAG core to transfer data between a PC and the board. I've read Virtual JTAG Intel FPGA IP Core user guide ,but there's something I didn't figure out:
1. Is there any detailed description of the virtual state machine? I learned to use some one-hot decoding like 'virtual_state_sdr' to tell my logic to get data from "TDI", but there isn't a concrete guide to tell me how to take advantage of all these state-machine signals.
2. In the example code below (excerpted from page 27),I know the "bypass_reg" is meant to let 'tdo' have some "value" when the 'vir' is selecting another virtual DR chain. But I don't totally understand why I should write code like the example( and 'bypass_reg <= tdi' is a syntax error) . Is there any timing diagram to illustrate how to execute a read or write transaction? I can't find this support.
// Bypass used to maintain the scan chain continuity for // tdi and tdo ports bypass_reg <= tdi; // Data Register Block always @ (posedge tck) if ( load && sdr ) tmp_reg <= {tdi, tmp_reg[3:1]}; // tdo Logic Block always @ (tmp_reg[0] or bypass_reg) if(load) tdo <= tmp_reg[0]; else tdo <= bypass_reg; endmodule
3. I can roughly know how to use 'sdr' 'e1dr' to perform a write transaction to the board, but there isn't an example to show how to read data from the board.
If there's any document for reference that can solve my questions, I will be very happy!
Thank you!
I have already solved this problem, and I'd like to share my experience with others.
1. No, the document of "virtual JTAG" is not that clear, but basically, we can use v_sdr to shift data both in read or write transaction; use v_cdr to indicate that parallel data which is to be transmitted to a PC should be prepared ready; use v_udr to read the shift register to get the parallel data output. Other states are not important.
2. If there's a read transaction (transmit data from FPGA to PC), shift data to 'tdo' when v_sdr high. If not, connect 'tdo' directly with 'tdi'.
3. The document can't help to provide more examples, write a test project is a better way to understand the usage of this core.
- YuanLi_S_Intel
Thank for your sharing. I am sure other people will be benefited as well.
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- RobertLiang
