15 years agoA erratic phenomenon of FIFO in FPGA
Hello, I am using megawizard to generate a fifo of 8bitsx1024words in EP3C16. An interesting result occurs, when fifo is full(wrfull=1), it at the same time indicates that there is no data to r...
15 years agothank you very much, kaz.
i think i do at last find the problem. it is the writing clock that causes so much exotic phenomenon, i am sorry for my careless checking this signal. thank you again for your patience and time. ingdxdy p.s. in fact, i donot trust simulation much. a lot of situations such as clock jitter, precise hareware timing cannot be simulated. i like running direclty and check with signaltap.
