15 years agoA erratic phenomenon of FIFO in FPGA
Hello, I am using megawizard to generate a fifo of 8bitsx1024words in EP3C16. An interesting result occurs, when fifo is full(wrfull=1), it at the same time indicates that there is no data to r...
15 years agoThats ok. I use half full just because it is easy to check using one bit logic.
I have never seen fifos behaving like what you see. I think it is best to use simulation of fifo on its own as I mentioned before.
