15 years agoA erratic phenomenon of FIFO in FPGA
Hello, I am using megawizard to generate a fifo of 8bitsx1024words in EP3C16. An interesting result occurs, when fifo is full(wrfull=1), it at the same time indicates that there is no data to r...
15 years ago --- Quote Start --- Optimising the operating point to the middle may waste a lot of memory, I'd rather say you optimise you system to keep fifos empty, but make them big enough to handle the bursts --- Quote End --- You may be thinking of using fifo just as fixed memory for block processing. But using fifo as "elastic" buffer for continuous stream processing and especially if the stream is bursty requires naturally that there is elasticity on both sides of operating point otherwise you get empty or full fifo repeatedly losing your stream continuity.
