11 years ago8xPMA Direct Transceivers CMU PLL at 6Gbps failed
Hey everyone, I was trying to use 8 channels (transmitter only) in PMA Direct mode with Stratix IV GX TR4 board (the device is GX230KF40C2). It worked fine at 4.8 Gbps, with CMU PLL. Howe...
11 years ago --- Quote Start --- Just wonder if you do not put any pin location assignment, select CMU PLL, will the Fitter pass compilation? --- Quote End --- I tried that as well, and the Fitter didn't pass. Thanks for pointing it out; I added this note in the main post.
