12 years ago800MHz counter on Cyclone ?
I need a high resolution (28 bits or more) with an 800MHz clock. Is it possible to use the VCO to clock a counter if I run the PLL with a M=8 multiplier with a 100Mhz to get a VCO of 800MHz ?
You might be able to generate it, but you'll violate the setup and hold of any internal logic.
Depending on what you want to achieve, multiple phase shifted clocks may be a solution. In any case, your design should be aware of the Cyclone hardware specifications.
--- Quote Start --- Depending on what you want to achieve, multiple phase shifted clocks may be a solution. In any case, your design should be aware of the Cyclone hardware specifications. --- Quote End --- That's what I was thinking. Is it possible to get all 8 phase shifted outputs (45,90,135...315 deg) from a single PLL output ? If so, my thought was to feed these 8 phase shifted outputs to latch FFs with a 100MHz clock for digital interpolation. I' pretty sure this is possible in Xilinx FPGAs and was hoping to do the same on a Cylcone II,III ? Thanks for all the help as I come up to speed ! - Altera_Forum
OK, I think I've got a working solution using all 5 of the PLL outputs each with a unique phase. Now onto figuring out how to implement the interpolator.
