12 years ago800MHz counter on Cyclone ?
I need a high resolution (28 bits or more) with an 800MHz clock. Is it possible to use the VCO to clock a counter if I run the PLL with a M=8 multiplier with a 100Mhz to get a VCO of 800MHz ?
12 years ago --- Quote Start --- Depending on what you want to achieve, multiple phase shifted clocks may be a solution. In any case, your design should be aware of the Cyclone hardware specifications. --- Quote End --- That's what I was thinking. Is it possible to get all 8 phase shifted outputs (45,90,135...315 deg) from a single PLL output ? If so, my thought was to feed these 8 phase shifted outputs to latch FFs with a 100MHz clock for digital interpolation. I' pretty sure this is possible in Xilinx FPGAs and was hoping to do the same on a Cylcone II,III ? Thanks for all the help as I come up to speed !
