12 years ago800MHz counter on Cyclone ?
I need a high resolution (28 bits or more) with an 800MHz clock. Is it possible to use the VCO to clock a counter if I run the PLL with a M=8 multiplier with a 100Mhz to get a VCO of 800MHz ?
12 years agoYou might be able to generate it, but you'll violate the setup and hold of any internal logic.
