14 years ago64bit linux port of jam byte-code player
I'm trying to port the 32bit linux jam-byte code player to 64bit linux. I think that I'm lost is all the size changes of longs, unsigned longs etc. since I seem to be able to do some operations just ...
14 years agoIt is working for me now on Scientific Linux 5. Here is my procedure:
- replace unsigned long with unsigned int - declare uint64_t_count and uint64_t_index explicitly in jbijtag.h - declaring the stack[] int instead of long (the -1 was getting screwed up in the stack) in jbimain - You may also need to play with your delay function. In SL5 the looping was optimized so the delay was an enormous number of loops, so I modified the loop function so it would not be optimized
