11 years ago5csxfc6c6u23i7n gpio
hi
i am using 5csxfc6c6u23i7n device (cyclone5 soc). i want to use its gpio pins, and i need a proper schematic of it regards!3 Replies
Which hardware platform? Mpression Helio?
Try this: helio board schematic (http://rocketboards.org/pub/documentation/macnicaheliosocevaluationkit/helio_board_sch_v1.2.pdf) Regards, Alex - Altera_Forum
hi
first thanks for the quick reply... but is seems like it isnt fits to 5csxfc6c6u23i7n regards :] - Altera_Forum
I assume you mean the '...I7N' suffix on your part doesn't match the '...C8N' suffix mentioned in the schematic. This just identifies the temperature rating and speed grade of the part.
So, assuming the schematic I pointed you to is the correct one (is it?) you don't need to worry about this bit of the device's part number. The pin information will be the same. Cheers, Alex
