16 years ago
50MHz to 1Hz
Hi,I am new planning FPGAs and I need to do a digital clock and I need a frequency of 1Hz. Someone would be able me to say as I obtain this frequency from 50MHz?
    Use a counter. In your 50MHz clock domain; count to 25,000,000. Each time you reach 25,000,000 toggle your 1Hz clock and reset your counter:
    module clk_1(
        input           clk_50mhz,
        input           reset_n,
        output  reg     clk_1hz
    reg   count;
    always @(posedge clk_50mhz or negedge reset_n)
        if(!reset_n) begin
                            count   <= 25'd2499999;
                            clk_1hz <= 1'b0;
        end else begin
                            count   <= count + 25'h1ffffff;
            if(!count) begin
                            clk_1hz <= ~clk_1hz;
            end
        end
    endmodule
    divide it by 50 000 000
    Depending on what you want to do with it, it may be a better idea to do a clock enable rather than a new clock signal.
