14 years ago
500Khz to 5-10Hz verlog LED divider
I want to create a 500Khz signal 3.3v to 5-10Hz verlog divider, for a led driver.
I have some experience of verlog and ideas.
Is there a simpler method of debugging that using model sim(altera).
Many Thanks
Dave
    Thanks Waiyung.
    I am using a de1 board to test divider and will use ext skt input 500KHz.
    I show the basic code below, for one led channel, could you tell me if it looks correct.
    module tim_counter(
    clk50M,
    // clk27M,
    //extclk,
    reset_N,
    ledout
    input clk50M;
    //output reg ledout;
    //input clk27M;
    //input extclk;
    input reset_N;
    output reg ledout;
    reg [15:0]counter;
    always @ (posedge clk50M or negedge reset_N)
    //always @ (posedge extclk or negedge reset_N)
    //always @ (posedge clk27M or negedge reset_N)
    begin
    if (!reset_N)
    begin
    counter <= 16'd0;
    ledout <= 1'b0;
    end
    else
    if (counter==16'd5000)
    begin
    counter <= 16'd0;
    ledout <= ~ ledout;
    end
    else
    begin
    counter <= counter +1;
    end
    end
    endmodule
    I use a top.v file and a pll.v file together with the divider file
    Thanks Dave
    From 500 kHz to 10 Hz is a ratio of 50 k = 50000. So a binary up counter 16 bit will give you a ratio of 65,536. If counter output is [15..0], then MSB [15] is ok for your application. If not, make the counter 17 bit, and outputs the MSB [16] to LED.
